Hello ![]()
Is there a quick note (apple notes) extension?
THX
What you can do is use the existing Notes Action and select an existing Quick Note to append a note to it. Each subsequent calling of the Notes Action recalls that specific note until you select a new note to append to or create a new note.
What is the workflow that you want to create a quick note rather than a regular note?
Sorry for the delayβ¦
I want to use the link feature of quick notes - add a web page link to the note
