Now that there’s a way to delete built-in extensions, is there a way to reinstall them, preferably without reinstalling PopClip? If not, can I suggest either adding them to the extension store or have them always available in the Extensions folder within Application Support.
You can restore built-in extension by using “New Instance” in the “Extensions” list ![]()
See video:
oh wow…I thought I had checked that…I must have assumed it was all the currently installed extensions. Sorry for the bother, but thanks for your help and I’m really loving the new update!
No worries! It’s not immediately obvious. Really glad you’re loving it.
With this update I’ve added a new page to the user guide that explains a lot of the new stuff: https://www.popclip.app/guide/organizing
And also Extension and Actions — what’s the difference?.
Keep exploring and feel free to ask about anything.
