Is there a way to export/save a PopClip installations configuration (ordered extensions) and the extensions?
Whilst there is no built in import/export or sync (yet), you can manually copy your existing extensions and settings to a different Mac by copying across the following:
Extensions folder:
`~/Library/Application Support/PopClip/Extensions`
Preferences file:
`~/Library/Preferences/com.pilotmoon.popclip.plist`
Perfect, exactly what I was looking for. Thanks
