I have the spell check extension installed but whenever I select text (on a forum or the eM Client editor) ir never pops up as an option I can use to check the spelling.
What am I missing? This is on MacOS Monterey 12.1
The built in Spelling action should appear when you select a single misspelled word in editable text for which there are any spelling suggestions available. The suggestions are made in the language you have set in the Spelling options. It doesn’t work on a block of text just on single words. I can post an example when I’m back at my computer.
Ah ha right, I was expecting ti to work on a lock of text
Mystery solved.
