I am using PopClip on a Mac. When I click on a misspelled word it shows the corrections but when I click on the correct work it doesn’t replace the misspelled word, it just goes back to the word, still misspelled.
Hi, thanks for the message @Shawn_NH and welcome to the forum.
Sounds like there’s a bug or maybe an incompatibility with a certain app. Normally, when you click this suggestion, it should replace the misspelt word. What app is this happening in? Does it happen in all apps or only in a certain app? For example, does it work in TextEdit?
Can you also please confirm the version of PopClip and the version of macOS?
I have both current versions of PopClip and Mac OS. After playing around some more, what I found was that if I tap to click it doesn’t work, even though I have the trackpad configured to treat the tap as a click. If I give a hard click it will work, sometimes it takes doing it twice.
This is not specific to any app. It happens wherever I use it. Most of my work is in Google Workspace, Mimestream, or Claude.
Do you have any other apps running that may be using the clipboard or monitoring mouse clicks (for example, mouse tools, clipboard tools, AI tools, or anything that does anything with text selection)?Sometimes two different apps can conflict and cause issues.
