Still not working after granting Accessibility permission
It didn’t work after I granted permission to Popclip. popclip still requires me to grant permission. I tried reinstalling and restarting the system. I installed the latest version on MAC OS tahoe. I haven’t tried using tools to completely uninstall Popclip (such as cleaner one) yet. Is there anyone like me?
As you sure it is granted in the list? (Not just clicking allow in the initial popup.)
One more thing, is PopClip running in the Applications folder? Apps can behave weird if run from elsewhere e.g. Downloads folder.
I solved it after I removed the Popclip from the list and added it back. Only on/off the switch doesn’t work.
Great – thank you for letting me and others know the solution that worked for you.
4 posts were split to a new topic: PopClip not launching
