Synonym extension?
I’m looking for a Synonym extension.
The best I myself came up with is
icon:  search S
url:  https://www.google.com/search?q=***+synonym
However, I’m sure there are better “direct” URLs.
Also, the coolest option would be if the extension would populate the synonym suggestions as a PopClip selection like with spelling suggestions. Is that possible?
There’s also Online Thesaurus extension which has a few built in options.
In-built suggestions would be cool. Needs a suitable data source (API or pre-baked data file of some kind).
