The bar location is not respected
Hello,
I am wondering if the placement of the PopClip bar is being properly respected. In my case, it is defined at the bottom, but that is not always the case. I assume that if it is located at the bottom of the screen, it should logically move above it; however, that is not what is happening.
I’m wondering if another application could interfere. I am indeed using another application that offers AI interactions with a popup in response; I have already submitted the request for this feature here ^^ but it’s a workaround solution while you can integrate it.
Thank you.
Hi, it’s a good question and comes up sometimes.
There is a small entry about this in the user guide
Note on position
The position setting only applies when you select a single line of text. If the selection includes multiple lines, the bar will appear below the pointer if you made the selection by moving the mouse downwards, and above the selection if you made the selection by moving the mouse upwards. This is to avoid the bar obscuring the selection.
See also: PopClip Getting Confused (Above/Below position setting)
Great, I hadn’t seen the post.
It’s not optimal, because as you mention, it goes over the text.
Can’t make it appear under the selection of a text block?
Thank you:)
PopClip bar shouldn’t be covering the text block – that’s the whole reason why it works like it does.
It should appear below the pointer (and thus below the text block) if you select downwards. Above the pointer (and thus above the text block) if you select upwards.
PopClip doesn’t know exactly where the selected text is, so it has to place itself relative to the pointer. Being near the pointer is also optimal for easy access to the bar.
If it’s not working right, could you record a short screen capture and post it for me so I can understand what you mean?
OK, I understand. I used your recommendation in your post above.
defaults write com.pilotmoon.popclip AlwaysRespectPositionSetting -bool YES
I should have been more explicit in my previous answer.
This is why the bar goes in front, but I understand that it is not possible to give the exact location of the selected text.
For now, this will do.
But I can make a video of the other constraint if you wish.
