Updated extension: Calculate
The Calculate extension is now updated to support macOS Monterey. It also gained some new abilities.
Full readme:
Calculate
Evaluate the text as mathematical expression.
Calculate-demo
The result is displated as the action’s button title. Clicking the action button will paste or copy the result. (Holding Shift (⇧) will always copy.)
Examples with simple arithmetic:
  • 1 + 1 → 2.
  • 15/2 → 7.5
  • (50 + 1) * 2 - 5 → 97.
It can also support quite complex expressions, as supported by mathjs:
  • 155 miles * 18% in km → 44.9006976 km
  • sqrt(4) → 2
  • sin(pi/2) → 1
  • 4(2 + 3i) → 8 + 12i
  • a = 2; b = 3; 2a + b → 7
If the input text ends with an = character, the result will be appended to the input instead of replacing it. For example:
  • 100/4= → 100/4=25
About
This is an extension for PopClip.
Author
Nick Moore
Requirements
Requires PopClip 2021.11.
Notes
The extension is implemented using mathjs. The evaluation is performed using the evaluate() function of the library.
Changelog
v2 - 8 Nov 2021
  • Rewritten in JavaScript using mathjs library.
  • Displays result as title of button.
v1 - 8 Apr 2013
  • Initial release (PHP).
Fabulous! I use this extension all the time, and the new features look great.
Thanks! :grinning:
Hi, thanks again… But one thing is missing (I think it was ok in the previous version !) : is it possible that Calculate use the , and not only the . for decimal values ??? In French we use the , as separator for the decimal values (defined in the prefs of macOS)
Thank you in advance
Ange
Thanks for mentioning this @Ange. I’m working on this but it is proving a little trickier than I thought. I’ll let you know when it is ready.
Thanks, perhaps through a pref for the calculate module with either a list of choices for the separator ? or to indicate which system we want to use (as the MacOS finder proposes) ?
I’ll see !
Regards,
Ange
I was planning to have it be the same as the macOS system preference. Would that be suitable?
It is not exactly as you show in your snapshot. Snapshot of my macOS prefs (main difference relative to your snapshot : position of the money symbol, words in FR without capitals ;-),
Ah yes, that’s because I have mine set to English and yours is set to Français. But I just mean, that the decimal separator (, or .) will be taken from the macOS setting.
so ok, it’s exactly that ! . or , !
Hello there! Is there any update on the , vs . matter?
I’m afraid not, it’s still waiting on my next PopClip update
Hello again!!
Another request!
Is it possible for the calculate extension to calculate time duration?
For example it would be nice to be able to convert “14:30 - 16:15” to “1h 45m”!
Thanks in advance.
Seem to have an issue with decimals & subtraction and Calculate Popclip (maybe just me?)
156055.43-156054.82 should = 0.61
Calculate PopClip result = 0.6099999999860302
Also an issue with addition & decimals
eg. 54.97+330.26+54.79 = 440.02
Calculate PopClip result = 440.02000000000004
Seems to be partly an issue with MathJS lib (at least version used)
I just tested here. https://mathnotepad.com . Same issues with subtraction & decimals, tho the addition seems to work ok on that scratchpad site (maybe version of lib they using)
It’s an issue with floating point arithmetic in general. Any math library that uses floats will be affected the same way. A classic example is 0.1 + 0.2 = 0.30000000000000004
Perhaps adding a default significant figure (configurable perhaps) for rounding will help.
Update: I’ve published an update to the extension that uses format{ precision: 14 } for output which should avoid these sorts of issues (as per mathjs docs)
