The Convert extension is updated for Monterey. It also now displays the result as the button title, saving a click.
Requires PopClip 2021.11.
Full readme:
Convert
Convert quantities in metric units to US/imperial units, and vice-versa.
Supports the following conversions: lb↔kg, oz↔g, miles↔km, feet/yards↔m, inches↔cm, °F↔°C.
The result will be shown as the action’s button title. Click the button to paste the result, or shift-click to copy it.
This is not a “scientific” converter, rather it attempts to parse the input as it might be encountered in ordinary writing, recipes, etc. Examples:
5 km,5km,5k,5K,5 kilometres,5 kilometers, all give the result3.1 miles.
2in,2"and2 inchesall give5.1 cm.
80F,80 °Fand80 fahrenheitall give26.7 °C.The output will attempt to match the number of decimal places of the input, so
5.000kmwill output3.107 miles. (However, the output will always have at least one decimal place.)Accepts either
,or.as the decimal separator in the input. The output decimal separator will be according to the current system locale.Does not accept numbers with thousdands separators in the input. (This would ne a nice improvement.)
Wikipedia links:
About
This is an extension for PopClip.
Requirements
Author
Nick Moore
Notes
This is a direct port of my original PHP code to TypeScript. I did look to see if there were any JavaScript libraries that did a similar thing, and I didn’t find any that replicated the behavior in quite the same way.
Changelog
v3 - Nov 4, 2021
- Updated for macOS Monterey, rewritten in TypeScript.
- Now displays the output in the button title itself.
v2 - 20 Oct 2020
- Fix error on newer PHP versions.
v1 - 16 Apr 2013
- Initial release (PHP).
