The TextSoap extension just updated. Now supports TextSoap 9.
You’ll need to install the free TextSoap Agent app to use the extension.
Enjoy!
Enjoy!
Thank you for considering the Setapp subscribers
I just installed the extension and it runs very well.
Again, one less shortcut to remember ![]()
That’s great - note that I just updated the extension again a few minutes ago to use the TextSoap Agent instead, it works much cleaner. (I edited the orignal post.)
Just installed and it looks very good. Thanks again ![]()
Really nice! I used to have several extensions to do various transformations on text and now I can get away with just using the TextSoap one. (I just discovered TextSoap.)
