Updated extension: Todoist
The Todoist extension is now updated to work on macOS Monterey.
Todoist
Add the selected text to Todoist.
The task can either be added to the Inbox (default), or to a specified project and section. You can also specify a due date for tasks, in Todoist’s natural language format.
Download: Todoist.popclipextz
About
This is an extension for PopClip.
Author
Nick Moore
Requirements
Requires PopClip 2021.11
Notes
Changelog
v5 — 4 Nov 2022
  • Added options to pre-specify a project, section and due date for tasks.
  • Formatting and links are preserved in the task’s text.
  • Updated to work with Todoist’s REST API v2.
v4 — 30 Mar 2022
  • Extension ported to JavaScript.
v3 — 11 Mar 2020
  • Updated to Todoist API v8.
v2 — 25 Aug 2016
  • Updated to Todoist API v7.
v1 - 30 May 2014
  • Initial release
Hello @nick! Thanks for this useful extension! Is it possible to add the option to add the task to a specific project and section, instead of the inbox? Thanks!
Not with the current extension as written. It may well be possible though. For now I’ll just leave these here:
I’ve updated the extension today, you can now (optionally) specify a project, section and due date. Download the update from: Todoist — PopClip Extensions
I’ve updated the readme at the top to reflect the latest version.
Hi! I love this app, but I use Todoist quite a bit and the integration isn’t working, so I can’t create tasks. The problem is that when I try to integrate my Todoist user with the app, it gives an error. It’s probably because Todoist has changed a URL or check.
If there’s any way to fix it, that would be great!
Thanks!
Sorry, yes there is an error with the server for the Todoist login at the moment. I’ll need to look into it. Thank you for reporting it.
