I am on version 2023.7 and I found a bug on Visual Studio Code, that’s actually quite annoying. On 99% of the time, the Cut, Paste and Paste+enter extensions don’t appear at all!
Is it a known issue and if yes, will it be addressed soon?
I confirm I can reproduce the bug. I have released a beta with a fix, available at https://pilotmoon.com/popclip/beta in Build 4163. If you get a chance to try it, please let me know if it works for you.
I just figured it out! If I select a piece of text by dragging, or by double-clicking and dragging the Backspace will appear . But, if I just double-click a piece of text, it won’t appear!
I can’t think of any reason why it would not appear, as it is defined to appear whenever Paste is available. Keep an eye out for if you see it not appear when Paste does appear. If you can, record it in a screen video and send it to me.
