I purchased PopClip. Could you add a feature that allows users to customize icons themselves? Because some plugins are not available in the plugin library and need to be added manually. For example, I added a quick search for Bilibili, but there is only a default search icon, which easily gets confused with other custom searches. So, could you add the ability to customize icons?
Yes, icon customization will be coming in the next PopClip update along with some other awesome stuff.
For now you can always make your own extension and set the icon that way.
See also: Introducing Extension Snippets
For anyone who can’t wait for the update, you can actually use the iconify: prefix in your snippets right now to grab specific icons (like iconify:mdi:search). It’s a bit of a manual workaround, but it works perfectly until the built-in customizer drops!
