Hi hi dear Mr. Nick,
Is it possible to add selected text to the specific Mac TextEdit?
if the existing text file end like「I love Popclip」,
and I selected “and Nick” form somewhere else,
it auto become to「I love Popclip and Nick」?
thank uuu <3
thank uuu <3
Something like:
icon: a
after: show-status
applescript: |
tell application "TextEdit"
set theDocument to first document
set text of theDocument to (text of theDocument & " {popclip text}")
Wow you are the God of Popclip!
but it seems need to open the file to do that.
You’ll need to have the file you want to append to open, yes.
Adapting this to Pages failed. Thoughts?
icon: P
after: show-status
applescript: |
tell application “Pages”
I suspect it’s an AS error, as compiling it in Script Editor gives syntax error:
Expected expression, property or key form, etc. but found unknown token.
The problem is the quotation marks around the word Pages. You have curly quotation marks but AppleScript requires straight quotes.
(Probably happened if typed into an editor with “smart quotes” turned on).
This with straight quotes returns “Invalid YAML” in TextEdit as plain text.
icon: P
after: show-status
applescript: |
Thoughts?
When composing a snippet it is important to ensure that the snippet itself is a valid YAML document. When using a multi-line string in YAML, with the pipe operator (|), it is necessary to indent each line of the string with spaces. Like this:
icon: P
after: show-status
applescript: |
tell application "Pages"
Note also that in the forum editor, I typed ``` on the lines before and after the code to format it as a code block. This should help avoid the possibility of the forum software adding smart quotes.
The above code should work. However, I recommend using the newer style snippet format, which avoids the fiddly indentation requirement, like this:
-- #popclip
-- name: Pages Append
-- icon: P
-- after: show-status
-- language: applescript
An advantage of this format is that the whole snippet is valid AppleScript code so you can edit it in the Script Editor:
Thanks - is there a link to documentation for the new format?
Item 6 at: New features for making extensions in PopClip 2022.12
There’s also some explanation about it in the main docs at https://github.com/pilotmoon/PopClip-Extensions#header-snippets
