Can Not Post Extension Snippet SOLVED
I finally got around to writing a Snippet to reformat US phone numbers.
Unfortunately, when I posted it to the Forum, the Snippet wasn’t recognized when selected.
For some reason, the software used for the Forum, Discourse, is apparently converting the characters #popclip into a link to https://forum.popclip.app/c/popclip/17 as you can see in this screenshot:
How do I upload this Extension?
// PopClip
// name: US Phone Number
// icon: square +1
// after: paste-result
const countryCode = ‘1’;
const prefix = ‘+’ + countryCode + ’ ';
const separator = ’ ';
const standardPhoneNumberLength = 10;
const selectedText = popclip.input.text;
let digitsOnly = selectedText.replace(/\D/g, ‘’);
if (digitsOnly.startsWith(countryCode)) {
digitsOnly = digitsOnly.slice(countryCode.length);
if (digitsOnly.length == standardPhoneNumberLength) {
return prefix + digitsOnly.slice(0,3) + separator + digitsOnly.slice(3,6) + separator + digitsOnly.slice(6);
return selectedText;
Apparently Discourse creates the link because there is no space between # and popclip even though that’s how it’s shown in the Developer’s Reference on Inverted Syntax.
The solution/workaround is to mark the Snippet’s entire block as pre-formatted text by placing three ticks ( `) above and below the block.
you can have the best of both worlds… the benefits of putting your snippet in a code block, AND js color coding, if you add the code type in the code block
```js
//js formatted code goes here
const countryCode = '1';                // US and other NANP countries
// etc
Yes that’s right – use either triple backticks, or press the code block formatting button in the edit box.
