I’d like an extension that changes a selected string of characters into a standard format for a phone number (if exactly 10 digits other than the optional leading country code are in the string) and adds the county code with plus sign (“+”) if it is not already present.
Having a setting for different countries is icing on the cake; I personally need it for the United States only but having different rules for different countries would be very cool.
Here’s my attempt on formatting phone numbers for countries that are members of the North American Numbering Plan, which includes the United States. I’ve included references to formatting phone numbers for other countries in case someone wants to extend it.
// name: US Phone Number
// icon: square +1
// after: paste-result
// Authoritative sources on formatting phone numbers:
// https://en.wikipedia.org/wiki/North_American_Numbering_Plan (NANP)
// https://en.wikipedia.org/wiki/E.123
// https://en.wikipedia.org/wiki/E.164
// Programming resources
// https://stackoverflow.com/questions/15745545/is-there-a-standard-for-phone-numbers
// https://github.com/google/libphonenumber
// Configuration Constants
const countryCode = '1'; // US and other NANP countries
const prefix = '+' + countryCode + ' '; // Plus sign (+) and space are required by E.123
const separator = ' '; // Spaces are default for E.123
const standardPhoneNumberLength = 10; // Full number for US and other NANP countries (including area code)
// Get text selected by PopClip
const selectedText = popclip.input.text;
// Remove all non-digit characters and countryCode, if any, from selectedText
let digitsOnly = selectedText.replace(/\D/g, '');
if (digitsOnly.startsWith(countryCode)) {
digitsOnly = digitsOnly.slice(countryCode.length);
// If the digits are the exact length of a standard phone number, return digits formatted with countryCode
if (digitsOnly.length == standardPhoneNumberLength) {
return prefix + digitsOnly.slice(0,3) + separator + digitsOnly.slice(3,6) + separator + digitsOnly.slice(6);
// Otherwise do nothing
return selectedText;
I was digging around in the tools I’m working with, trying to get them to realize that ( and ) are NOT the way.
We settled on E.164, which would beg this minimal set of changes:
-const separator = ' '; // Spaces are default for E.123
+const separator = '-'; // Spaces are frowned upon in E.164
-const prefix = '+' + countryCode + ' '; // Plus sign (+) and space are required by E.123
+const prefix = '+' + countryCode + '-'; // Plus sign (+) is required by E.123, the - is suggested by E.164
So, my version is largely the same as yours, but set the separator first and uses it in the prefix
phone.popcliptxt
// icon: square +1
// Authored by Nello + Allen
// https://forum.popclip.app/t/format-phone-numbers/1536
const prefix = '+' + countryCode; // Plus sign (+) is required by E.123
const prefixSeparator = '-' // A space ' ' is required by E.123, a '-' dash is suggested by E.164
const bodySeparator = '-'; // Use spaces ' ' for E.123 format, use a '-' dash for E.164
return prefix + prefixSeparator + digitsOnly.slice(0,3) + bodySeparator + digitsOnly.slice(3,6) + bodySeparator + digitsOnly.slice(6);
Thank you for doing the hard work here!
And thankfully, I didn’t have to bother adding a conditional to use parenthesis
I want to share my PopClip extension: PopClip Phone Formatter.
This extension smartly formats phone numbers with support for extension numbers and localization in 15 languages.
It supports three output formats:
• Contacts (E.164 format, e.g. +79001234567,123)
• Documents (International format, e.g. +7 900 123 45 67 ext. 123)
• Web (tel: URI, e.g. tel:+79001234567;ext=123)
It currently covers 42 countries with accurate parsing using libphonenumber-js and fallback parsing if needed.
This version uses a modifier key to define the format of the phone number. Without the modifier key, the format is (123) 456-7890
With the SHIFT as modifier, the format is +1-555-123-4567
Also, this version copies the formatted number to the clipboard instead of immediately pasting back.
// name: Copy Phone (Shift=Intl)
// icon: 📞
// after: copy-result
// Get text
// Strip leading '1' if the number is 11 digits
if (digitsOnly.length === 11 && digitsOnly.startsWith('1')) {
digitsOnly = digitsOnly.slice(1);
// Only proceed if we have exactly 10 digits
if (digitsOnly.length === 10) {
// Check if SHIFT is held down
const useInternational = popclip.modifiers.shift;
if (useInternational) {
// International Format: +1-555-123-4567
return '+1-' + digitsOnly.slice(0,3) + '-' + digitsOnly.slice(3,6) + '-' + digitsOnly.slice(6);
} else {
// US Format: (555) 123-4567
return '(' + digitsOnly.slice(0,3) + ') ' + digitsOnly.slice(3,6) + '-' + digitsOnly.slice(6);
// If it's not a valid phone number, just copy the original text
