Hi! I’m wondering if there’s a single operation in the works to change a hyphenated compound word directly a solid compound. Example: tree-top to treetop.
The Hypenate extension will do this.
Edit: my bad
// name: Remove hyphens
// icon: monospaced square -
// after: paste-result
return popclip.input.text.replaceAll("-", "")
As as copy editor, I’ve needed something this for years! Thank you x 1,000!
