Looks like preserve color: true or preserve image color: true stops working after upgrading from 2023.9 to 2024.3.1. The icon is black now.
icon: SomeIcon.png
url: https://xxx.com?query=***
icon: SomeIcon.png
It’s supposed to work, but I just tested it, and it doesnt!
I’ll get on it.
Thanks for reporting this, @zzz.
Thanks Nick!
Another question: which one is preferred: preserve color or preserve image color?
preserve color is the preferred. (preserve image color also still works fine but is deprecated.)
Latest icon docs: Icons — PopClip Developer
I will fix this properly in the next version, but for now I have a workaround for you:
instead of:
icon: SomeIcon.png
do
icon: preserve_color file:SomeIcon.png
Please could you let me know if this is fixed for you in beta Build 4516?
Sometimes I am confused that in doc it’s preserve_color (underscore) while in the installation script it’s preserve color (space)
Thanks, Nick. It works!
Yeah, that’s annoying me in the docs too. You can put preserve_color for both if you want. Or preserveColor. Or PreserveColor. Whatever floats your boat.
That’s probably confused you more I guess.
You just can’t have it with a space in the icon string.
Do you mean all keywords can use this pattern?
For example:
Yes. See “key names” at The config dictionary — PopClip Developer
Thanks for the information!
