zzz
May 14, 2024, 1:36am
1
Looks like preserve color: true stops working after upgrading from 2024.3.2 to 2024.5.1. The icon is black now.
icon: SomeIcon.png
url: https://xxx.com?query=***
Same as this issue Does "Preserve Color" still work on PopClip 2024.3.1?
nick
May 14, 2024, 6:15am
2
Dammit, I broke preserve color again
But you can stil do it like this:
icon: "preserve-color file:SomeIcon.png"
Thanks for reporting it. I will restore the preserve color: true method it in the next version.
zzz
May 14, 2024, 6:35am
4
How to set preserve color: false with below format? Just remove the preserve-color prefix?
nick
May 14, 2024, 6:49am
5
Yep just omit the modifier and it won’t have effect.
To explicitly negate, you can put preserve-color=0 but that would only be needed if your icon had intrinsic color, which is the case for some Iconify icons and also where you specify the icon as an Emoji.
Some docs tucked away at the bottom at https://www.popclip.app/dev/icons#color-and-aspect
(Or download Build 4588 which restores compatibility with the old way.)
