I wanted an extension that would save me a few clicks and insert an Apple emoji / symbol icon. Simple enough? Sure, but I scoured the forums and couldn’t find one. I wanted to have ‘in a click’ offline use of Apple emojis. So, I did the next best thing, I asked PopClip’s ChatGPT extension to build me one. This is what the ensuing conversation looked like:
Make me a PopClip extension to insert an emoji
As an AI language model, I cannot create PopClip extensions. However, here’s an example of how to create a PopClip extension to insert an emoji on macOS:
1. Open Script Editor on your Mac (You can find it in the Applications > Utilities folder)
2. Select “New Document” and choose “Script” as the document type
3. Paste the following code into the Script Editor:
#!/usr/bin/osascript
on run argv
set theEmoji to item 1 of argv
keystroke theEmoji
end run
4. Save the script as “Insert Emoji” in the following path: ~/Library/Application Support/Popclip/Extensions
5. Open PopClip and choose “Customize” from the drop-down menu.
6. Drag and drop the “Insert Emoji” extension from the list of extensions to the PopClip menu
7. To use the extension, select the text you want to replace with an emoji, then click on the PopClip menu and select “Insert Emoji” from the list of options. Choose the emoji you want to insert from the picker.
Note: you can customize the extension by modifying the set theEmoji to item 1 of argv line to insert a specific emoji instead of getting it from the PopClip menu.
Your instructions are faulty. There is no way to choose “Customize” from the drop-down menu.
I apologize for any confusion. Without more specific information, it’s difficult to determine what may be causing this issue or provide a clear solution. Can you please provide more context or details about what program or website you are working with and what tasks you are trying to perform? This will help me better assist you.
I initially asked that you “Make me a PopClip extension to insert an emoji” and you replied with this example:
on run argv
keystroke theEmoji
end run
But upon review there is no way to choose “Customize” from the drop-down menu.
I apologize for the confusion. It seems that the instructions I provided were for an older version of PopClip. Here are updated instructions for PopClip version 2021.6:
on run argv
keystroke theEmoji
end run
4. Save the script as “Insert Emoji” in the following path: ~/Library/Containers/com.pilotmoon.popclip/Data/Library/Application Support/PopClip/Extensions/
5. If PopClip is already open, quit and relaunch it.
6. Click on the PopClip icon in the menu bar and choose “Customize Extensions”
7. Drag and drop the “Insert Emoji” extension from the list of extensions to the PopClip menu
8. To use the extension, select the text you want to replace with an emoji, then click on the PopClip menu and select “Insert Emoji” from the list of options. Choose the emoji you want to insert from the picker.
I hope this helps! Let me know if you have any further questions.
Once again, your instructions are faulty. There is no way to choose “Customize Extensions” from a drop-down menu.
Obviously I will need to ask Nick, the great and powerful developer of PopClip.
Thanks but no thanks.
As an AI language model, I apologize for providing faulty instructions. It is understandable that you would seek assistance from the developer of the program. Thank you for your feedback, and I hope you are able to resolve your issue with PopClip.
Between us @nick my issue is not with your most wonderful PopClip app but rather with ChatGPT being ill informed.
Can you, for us all who are also looking to build this extension, straigten us out?
{{ I don’t expect AI to replace you Nick Moore or your deskside manor anytime soon }}
