Example snippet: Use of regex, copy to clipboard (remove $ symbols)
By Email:
If I copy some text; while pasting, I need to tinker with the copied text; then how can I do that?
For example, if I am copying the math/LaTeX Code:
$x+y=2$ … and when I copy it, by default, it takes, that dollar sign as well and when I want to paste it somewhere else, I no longer required those dollar signs, so how do I get rid of that?
Moreover, this is just a sample question… but I might have more complex situations… for example, I need to remove $ and then the earlier LaTeX environment as well… and similarly, in the last also, $ and subsequent environments, then how to do that?
Is there any quick command to do such kind of thing?
This could be done with a PopClip extension as follows:
// name: Remove $
// regex: \$.+\$
// icon: circle monospaced $
const result = popclip.input.matchedText.slice(1,-1);
popclip.copyText(result);
Explanation:
  • the regex: \$.+\$ matches inputs containing $...$ capturing everything between the first and last $.
  • The .slice(1,-1) removes the first and last character
  • popclip.copyText() copies the result to the clipboard.
For other situations, you would of course need to modify the regex and code accordingly. I hope this provides a starting point.
W@W…
This is what I wanted…You are Great, Nick!
I am so blessed to have you has a mentor in this!
Regards,
Dr. Dishant
