I was thinking years ago there was a bible verse extension for PopClip but my searches within the Forum and through the extension list is not showing up with anything.
And was able to get it running by downloading all the files and putting them into a folder with a popclipext extension then compressing the folder with an popclipextz extension and it works but it’s also a version of the Bible I don’t use that often and would be great to have an option or setting to have the completed version of a verse appear above the highlighted text.
Primarily looking for ESV or NASB in addition to KJV / NKJV.
Would also be great just to see what others have come up with.
For just searching one of your sites you can build a simple snippet using the examples on Snippets — PopClip Developer.
If you want to select a reference and PopClip should get the whole verse in the background and put it on the clipboard, you need some platform that provides an API.
"verse": "16",
"text": "¶ For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life."
The main “trick” will with this api be processing the text input into the correct URL.
Thank you everyone for the help, I was initially hoping there was an existing extension I overlooked however the suggestions and guidance were very welcomed and appreciated as I know enough to possibly come up with my own solution.
Thank you again to everyone!
Edit: With the replies and along with this post:
I’ve got some ideas I can run with, much appreciated!
