Extension for OpenStreetMap
A simple extension to search OpenStreetMap, using the standard layer from https://www.openstreetmap.org.
Version 1: PopClip action appears under OSM
icon: circle filled OSM
url: https://www.openstreetmap.org/search?query=***
description: OpenStreetMap search
(The above block is an extension snippet – select it to install the extension with PopClip)
Version 2: PopClip action appears with icon
icon: iconify:simple-icons:openstreetmap
Try it out:
1 Infinite Loop, Cupertino, CA 95014
Seems the direcotrty could do with an OSM ext, I used this as the basis for #popclip-osm.yaml · GitHub
