Extension ideas for searching media (Metacritic, Genius and JustWatch)
Would be possible to create these extensions for searching media?
  • Search in Metacritic
  • Search in Genius
  • Search in JustWatch
It would be awesome! :slight_smile:
Hi, I made that simple extensions, just double click on the popclipext files to add them and use as you want! Bye!! :grinning:
Lovely job @JumpinJack and with icons, very nice.
Thanks a lot! Looks great!
I downloaded these extensions and agree they look great. I’ve noticed, however, that the Just Watch extension takes me to the Italian version. I would like to update the extension so that it directs my searches to the US version of Just Watch, but I’m not sure how to view the code for the extension. I’m sure there is an easy way to do this, but I’m a novice and could use some guidance.
Briefly, the .popclipext “file” is actually a folder, which you can view the contents of by right clicking in Finder and clicking Show Package Contents.
Once inside the folder you will see Config.plist file. Use a text editor (TextEdit in plain text mode will do) to change the URL in the Config.plist file.
Then go back up to the .popclipext and double click to reinstall.
Here’s a video showing this: CleanShot 2022-03-14 at 06.56.35-converted · CleanShot Cloud
Do you still have these since link is expired? Would be great!
Sorry, I no longer have those extensions, but now there’s a very easier and faster method to make it, explained here: Introducing Extension Snippets
Here is Metacritic search Snippet if someone else need it.
icon: square filled m
url: https://www.metacritic.com/search/game/=***/results
Great Job, thanks for sharing.
Hi, I made the extension for JustWatch because I needed it for myself. The default region is Australia, but you can choose between Italy, US and UK (or you can add your favorite regions by changing “values: [au, it, us, uk]”).
icon: svg:<svg width="512" height="512" xmlns="http://www.w3.org/2000/svg"><path fill-rule="evenodd" d="M35.84 501.806c-3.435.46-8.32.075-10.854-.853-2.533-.929-6.55-5.08-8.924-9.226-4.113-7.18-4.348-9.278-4.94-44.13-.342-20.125.06-40.206.893-44.624 1.39-7.373 1.924-8.004 6.51-7.684 2.75.192 27.165 11.777 54.258 25.747 27.092 13.969 51.261 27.12 53.708 29.225 4.449 3.826 4.449 3.826-.45 7.68-2.694 2.118-22.685 12.667-44.425 23.441s-42.34 19.965-45.775 20.424Zm112.431-55.994c-2.817 0-5.67-.886-6.339-1.969-.67-1.082-1.635-24.629-2.146-52.325-.766-41.499-.48-51.278 1.629-55.596 2.059-4.216 3.632-5.193 8.05-5.002 3.02.13 18.249 6.856 33.842 14.946 15.594 8.09 37.435 19.57 48.536 25.51 11.102 5.94 20.97 12.266 21.929 14.059 1.138 2.126 1.132 4.4-.015 6.545-.967 1.807-12.441 8.795-25.498 15.529a14151.135 14151.135 0 0 1-49.303 25.273c-14.16 7.218-27.848 13.03-30.685 13.03Zm128.43-62.962c-1.55.405-3.967-.659-5.37-2.364-2.11-2.562-2.48-12.29-2.127-55.904.234-29.042 1.137-54.008 2.005-55.48.87-1.473 3.89-2.638 6.714-2.59 2.854.048 19.401 7.48 37.263 16.736 17.671 9.156 39.615 20.72 48.765 25.697 9.149 4.977 17.49 10.648 18.535 12.6 1.585 2.962 1.016 4.342-3.423 8.308-2.928 2.616-26.523 15.445-52.433 28.508-25.91 13.064-48.378 24.083-49.929 24.489Zm-255.14-4.066c-2.454.561-5.667.24-7.14-.715-2.25-1.459-2.77-9.64-3.254-51.251-.317-27.234-.073-52.201.542-55.483.714-3.805 2.6-6.642 5.204-7.828 3.44-1.568 6.996-.36 22.573 7.668 10.17 5.24 26.194 13.545 35.611 18.454 9.417 4.908 24.45 12.786 33.405 17.505 8.956 4.72 16.75 9.798 17.32 11.286.572 1.487.308 4.069-.585 5.737-.893 1.669-7.517 6.36-14.72 10.426-7.202 4.066-29.16 15.444-48.794 25.286-19.635 9.842-37.708 18.353-40.162 18.915Zm125.499-63.275c-2.151 0-4.561-1.003-5.355-2.23-.795-1.227-1.704-24.282-2.021-51.233-.318-26.951-.073-51.688.542-54.97.713-3.801 2.6-6.641 5.199-7.826 3.462-1.577 7.833.032 28.909 10.64 13.657 6.875 36.784 18.787 51.394 26.472 17.68 9.3 27.19 15.346 28.434 18.078 1.509 3.31 1.204 4.752-1.574 7.457-1.895 1.844-15.092 9.54-29.327 17.103-14.235 7.563-36.324 18.871-49.086 25.13-12.763 6.257-24.965 11.378-27.115 11.38Zm256.73-.026c-.627-.015-2.308-.765-3.734-1.667-1.895-1.2-2.939-7.315-3.88-22.731-.709-11.6-1.338-35.147-1.398-52.328-.077-22.073.562-32.545 2.178-35.699 1.524-2.973 3.75-4.437 6.668-4.387 2.409.04 20.444 8.382 40.079 18.536 19.634 10.154 39.618 20.914 44.408 23.91 5.578 3.49 9.623 7.635 11.25 11.53 2.232 5.34 2.206 6.596-.212 10.286-1.514 2.311-8.184 7.375-14.82 11.252-6.637 3.876-27.216 14.76-45.732 24.187-18.516 9.426-34.18 17.126-34.807 17.111ZM19.985 250.68c-1.725.451-4.284-.564-5.688-2.256-2.083-2.51-2.553-12.5-2.553-54.276 0-30.887.736-53.262 1.854-56.398 1.38-3.866 2.98-5.18 6.248-5.129 2.416.038 24.875 10.709 49.909 23.712 25.034 13.004 47.524 25.108 49.979 26.899 2.912 2.124 4.462 4.981 4.462 8.224 0 3.243-1.55 6.1-4.462 8.224-2.455 1.79-25.197 13.812-50.538 26.717-25.342 12.905-47.486 23.832-49.211 24.283Zm257.357-3.684c-5.157.99-5.855.598-7.14-4.017-.784-2.813-1.263-27.939-1.065-55.835.305-42.995.779-51.14 3.113-53.474 2.219-2.219 4.054-2.401 9.457-.938 3.688.998 27.187 12.498 52.221 25.554 25.034 13.057 46.663 24.828 48.064 26.158 1.992 1.89 2.118 3.362.576 6.746-1.369 3.004-9.797 8.43-27.537 17.727-14.061 7.37-36.007 18.705-48.77 25.19-12.762 6.485-25.776 12.285-28.92 12.89Zm-126.85-64.365c-2.682.49-6.081.094-7.554-.878-2.283-1.507-2.677-9.793-2.677-56.21 0-49.481.284-54.727 3.125-57.568 2.925-2.926 3.612-2.941 10.71-.233 4.171 1.592 25.657 12.28 47.746 23.75 22.088 11.47 42.759 22.59 45.934 24.71 3.175 2.121 6.162 4.86 6.638 6.087.475 1.227.46 3.283-.033 4.568-.493 1.285-5.086 4.803-10.207 7.817-5.12 3.014-20.958 11.4-35.193 18.636-14.235 7.236-26.29 13.558-26.791 14.05-.5.49-6.74 3.927-13.866 7.636-7.126 3.71-15.151 7.146-17.833 7.635ZM19.33 117.063c-6.694.692-6.694.692-6.651-40.995.023-22.929.784-44.9 1.69-48.828 1.007-4.364 3.865-9.126 7.35-12.25 4.706-4.216 6.854-4.955 12.286-4.226 3.62.485 18.968 6.643 34.107 13.683 15.138 7.04 35.155 17.061 44.482 22.269 9.326 5.207 16.957 10.44 16.957 11.63 0 1.189-4.798 5.316-10.662 9.172-5.864 3.856-29.157 16.425-51.764 27.931-24.372 12.406-43.826 21.203-47.795 21.614Z"/></svg>
url: https://www.justwatch.com/{popclip option site}/search?q=***
options: [{identifier: site, type: multiple, label: Region, defaultValue: au, values: [au, it, us, uk]}]
Fantastic job, thanks!
