By email:
Any chance of adding a trigger for “start dictation”?
This one needs a tiny bit of set-up.
First go to System Settings → Keyboard and scroll down to Dictation. Set a shortcut and choose the custom option. Set a shortcut combination of your choice. Here, I’m choosing ⌃⌥⌘D:
Next, either use the following snippet, or edit it if you chose a different shortcut to me:
name: Start Dictation
icon: symbol:mic
requirements: [paste]
key combo: control option command D
Then long-press to show PopClip in any editable field, and you should see the microphone icon to triggger dictation.
