Hello folks,
I am trying to modify the default extension called Brackets-awjzhy-177 which wraps selected text between curly brackets {}. I am trying to edit the config file but I can’t figure out the part where I put my own modification.
My modification would simply do the following: it wrap the selected text with the following
{{c1:: selected text goes in here }}
Then I would upload and tie to the key shortcut to bring up when I need it.
What’s the best way to accomplish.
Thanks,
George
