I’d like to selected a line or two of text and have Popclip add an asterisk and space to the beginning of each line so that Markdown treats it as an unordered list.
I would use this mostly within DEVONthink to modify text items.
Thanks!
Thanks!
Love this. I would use it too.
Of course, it would be nice to create an ordered list (1, 2, 3, etc) as well.
# popclip (maybe you need to change the icons 😂)
icon: ML
actions:
- title: Begin with Number
icon: text:123
javascript: return '1. ' + popclip.input.text.replace(/\n/g, '\n1. ')
after: paste-result
- title: Begin with Dot
icon: text:...
javascript: return '- ' + popclip.input.text.replace(/\n/g, '\n- ')
after: paste-result
This is wonderful! Can you make it so that it copies that text and link in Markdown? Nick made the following, and it would be wonderful to have your features of making a list…
name: MD Copy with Link
icon: symbol:link.circle.fill
capture html: true
let text = popclip.input.markdown
if (popclip.context.browserUrl.length > 0) {
text += ‘\n\n[’ + popclip.context.browserTitle + ‘](’ + popclip.context.browserUrl + ‘)’
popclip.copyText(text)
I’m not quite sure if the below is what you want
icon: symbol:list.star
capture html: true
actions:
- title: Numbered List
icon: symbol:list.number
popclip.copyText('1. ' + popclip.input.markdown.replace(/\n/g, '\n1. '))
- title: Bulleted List
icon: symbol:list.bullet
popclip.copyText('- ' + popclip.input.markdown.replace(/\n/g, '\n- '))
Yes, everything is great, including turning the links into markdown in the content being copied… the thing I am looking for is the markdown link at the end for the URL of the source.
Nick already did this, but he didn’t have the listing elements you have added. Here is Nick’s:
Like this?
capture html: true
actions:
popclip.copyText('1. ' + popclip.input.markdown.replace(/\n/g, '\n1. ') + (popclip.context.browserUrl.length > 0 ? ' [' + popclip.context.browserTitle + '](' + popclip.context.browserUrl + ')' : ''))
popclip.copyText('- ' + popclip.input.markdown.replace(/\n/g, '\n- ') + (popclip.context.browserUrl.length > 0 ? ' [' + popclip.context.browserTitle + '](' + popclip.context.browserUrl + ')' : ''))
Oh baby yes!! One last little detail… if the URL link at the end is connected at the end of the content instead of on the next line.
Wow, this will be such a great tool. Thanks for your work on this!!!
Stan
/2022-02-06_20-35-45.png)
So it would look like this…
/2022-02-06_20-54-02.png)
Ok, updated, try to reinstall the script
Which is the updated version?
Perfect!!! Thank you so much! This is an amazing tool!
Post #8 is the one…
great work everyone! ![]()
It is the first of the two attachments above… Thanks Nick for all your work on this!! Stan
