Works like before but also works on RTF and plain text selections now too. The update will be required for compatibility with Monterey 12.3, which is currently in beta.
Copy as Markdown β PopClip Extensions
Copy as Markdown
Copy web page content as Markdown source code. Also works on plain text and RTF content.
About
This is an extension for PopClip.
Author
Nick Moore
Requirements
Requires PopClip 2021.11.
Notes
The original extension used html2text by Aaron Swartz.
The updated JavaScript extension uses PopClipβs inbuilt markdownifier, which uses Turndown.
Hat-tip to Brett Terpstra whose Web Markdownifier extension inspired this one.
Changelog
v2 - 3 Feb 2022
- Rewritten in JavaScript & Turndown.
v1 - 7 Dec 2016
- Initial release (Python & html2text)
See also β X β : Extension failing (re. Copy as Markdown)
