Paste Wikilink as Text Alias in Obsidian
Hi,
I am trying to use this for pasting Wikilinks from my clipboard into an Obsidian note as an alias for the selected text:
icon: link
requirements: []
actions:
  - type: paste
    content: "[[%clipboard%|%text%]]"
The extension remains greyed out. What am I missing?
There are no fields named ‘type’ or ‘content’ in the action, so PopClip ignores them and perceives it as an “empty” action, resulting in a grayed-out icon.
Did you get this snippet from an LLM? Unfortunately, it seems to have hallucinated some non-existent fields, which can happen when they attempt to create PopClip extensions.
Based on what it looks like you are trying to achieve, this should work:
// name: Obsidian WikiLink
// icon: link
// requirements: []
popclip.pasteText(`[[${pasteboard.text}|${popclip.input.text}]]`);
Thanks a lot, Nick. Yes, I was using Claude to help with the code and it seems that it went on a hallucination trip :sweat_smile:
Hi @nick , saw your answer and was hoping you could suggest an extension snippet that does the following: copy a selected header in an Obsidian note to the MacOS clipboard as [[NoteTitle#Heading]]. So that I can create a ‘Link to this Header’ extension. Thanks!
