PopClip 2024.12 is now available on the PopClip website and on Setapp.
What’s new
This is a maintenance release that improves compatibility and reliability, and squashes a few bugs. In particular:
- Fixed some situations where PopClip would fail to appear when selecting text.
- Pressing ⌘C sometimes had no effect when pressed simultaneously with PopClip appearing.
- The Open URL action now supports the lt: (LiquidText) URL scheme.
There are also several updates for extension development; see the
Developer Changelog for full details.
Version information
- App: PopClip, https://www.popclip.app/
- Version: 2024.12 (4688)
- Release date: December 18, 2024
- Requirements: macOS version 10.15.7 and above; Apple Silicon or Intel processor.
Updating your existing app
Mac App Store Edition
This update is not available via the Mac App Store. As I announced in March, PopClip has left the Mac App Store. To receive this update, please follow the migration instructions.
Standalone Edition
You can trigger an update by un-checking and re-checking the Check for Updates checkbox.
Setapp Edition
The update will be automatically installed by Setapp. You can manually trigger the update by clicking “Check for Updates…” in the Setapp menu.
Homebrew
If you installed PopClip via homebrew, you can run brew upgrade popclip.
