Quotes ext: add asterisk?
A suggestion for any Quotes extension update: add the * as another character option. Some website comments sections use this to indicate italics.
Alternatively, I could probably figure out how to make a snippet that would do the same thing. But my PopClip popup (is this what you mean by “rack”?) is already kind of unwieldy…although a snippet with a number of options could replace the standard Quotes ext…
Bump.
Is it possible to add asterisks to the Quotes extension?
I was just getting ready to ask this question and discovered that I had asked it months ago with no replies.
Bump again. I would also like to add parentheses and square brackets to the list of options.
Brackets and Parentheses are available in the Brackets extension
Here’s an action for asterisks:
icon: monospaced *
javascript: popclip.pasteText(`*${popclip.input.text}*`)
