Redacting each character in a selection
How would you create an extension that replaces each character in a selection with a special character, perhaps a ▬? Doing so would redact the selected text, while maintaining the same length. Spaces could be replaced as well so that it isn’t necessary to treat them separately.
Examples:
Redact the word Popclip from this sentence.
Redact the word ▬ ▬ ▬ ▬ ▬ ▬ ▬ from this sentence.
Redact the next word from this sentence.
Redact the next ▬ ▬ ▬ ▬ from this sentence.
Redact the next three words from this sentence.
Redact the next ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ ▬ this sentence.
This ought to do it:
// name: Redact
// after: paste-result
return "▬".repeat(popclip.input.text.length)
Wonderful!
