By email:
Hello, I’m a Popclip fan.
A question about a feature:
when coding, I often create lines like /* margin: 1rem; */
My wish would be to have a popclip function that would be able to delete the /* */ elements.
Is popclip able to do that?
Here’s a snippet for that:
// name: Remove /* */
// icon: strike monospaced /*
popclip.pasteText(
popclip.input.text.replace(/\/\*\s*|\s*\*\//g, '')
In use:
