Is it possible to write a Snippet which executes a macOS shortcut after it terminates?
Or alternatively which executes another PopCip action?
For example I would like to use the new “Copy with Link” PopCip extension and then either run a Shortcut which sends the Clipboard contents as a Message or which passes the Cilpboard contents to the existing Messages extension.
Chaining Popclip extensions would be great … then you could have an extension that runs a shortcut from a URL scheme, and call it as from another action.
Shortcuts absolutely … I’ll do a full “How to” post on it soon but it’s as simple as:
shortcut name: Shortcut Name Here
Extension chaining is definitely an exciting possibilty. It’s not currenrtly possible, but this is definitely one of the bats up there in in the ideas belfry. As always it’s just a case of one thing at a time…
Not complaining! I’m impressed at how much you are adding, and how quickly. Even without chaining, the snippet feature is so simple to use, it’s easy enough to make compound actions by reusing bits of code, etc.
@rkaplan these are not PopClip extension. I have only arranged the Keybaord Maestro macros in the style of PopClip, because I wanted to have the screenshot selection directly at the cursor.
