would it be very difficult to create an extension which puts a space in between each letter of a selected word/s and at the beginning and end of the word/s?
so popclip becomes
p o p c l i p
so popclip becomes
p o p c l i p
Something like:
// name: S p a c e d w o r d s
// icon: sw
// after: paste-result
let result = "";
for (const c of popclip.input.text) {
result += " " + c;
return result.trim();
Note inserting the spaces will mess up with some emoji, e.g.
becomes
and
becomes 🇦 🇺 .
this is a w e s o m e ! thank you so much!!
