A quickie snippet I just made while exploring making a Raycast extension:
#popclip extension snippet to send text to Raycast
icon: R
before: copy
url: raycast://
after: paste
It’s a bit fragile because it relies on timing to work. If the Raycast window doesn’t pop up soon enough (e.g. if Raycast isn’t running) it will paste too soon. But generally works well.
Can’t find any info on Raycast URL scheme to actually pass it the text…
