Theme in auto setting not working
After updating to the latest version having theme set to auto no longer works.
Expected behavior:
The theme changes from light to dark or dark to light together with the Mac theme.
Actual behavior:
The theme gets stuck in light or dark theme and doesn’t change.
You have to change it manually to a different setting and back to auto in order to change the theme.
Noted – thanks for reporting it! Yes, I can reproduce this also. Fix will be coming.
Now fixed in beta - see PopClip Beta discussion (after 2025.9)
