Updated extension: TaskPaper
The TaskPaper extension is also updated for Monterey:
TaskPaper
Send the text to TaskPaper 3 (“Plain text to-do lists for Mac”).
Download: TaskPaper.popclipextz
Description
The extension has one action, which takes the selected plain text and adds it as a new task in the Inbox project of the open TaskPaper document.
If no TaskPaper document is currently open, the extension will show an “X”.
About
This is an extension for PopClip.
Author
Nick Moore
Acknowledgements
The JSX script used is based on the one posted by Jesse Grosjean at the Hog Bay Software forum.
Requirements
Requires PopClip 2022.5
Links
Changelog
5 May 2022
  • Updated for compatibility with macOS Monterey.
8 Oct 2019
  • Removed support for TaskPaper 2.
27 Jan 2017
  • Updated to add support for the version of Taskpaper that comes with Setapp.
20 May 2016
  • Updated to support TaskPaper 3. Required use of scripting interface because TP3 does not have the “send to inbox” service.
14 Nov 2012
  • Initial release
I was typing a Q about an app store update, when it appeared!
and I can confirm it doesn’t work on the non-updated version :grinning: just as it says in the documentation.
@nick would it be possible to update the tp.scpt in this one to add the taskpaper marker text before the insert so that the text shows up in the inbox as a task instead of a note?
var taskText = "- " + options.text;
var items = ItemSerializer.deserializeItems(taskText, outline, ItemSerializer.TEXTMimeType);
thanks!
Updated!: TaskPaper — PopClip Extensions
But need a new GIF.
